74 Shortbed
- Aug 12, 2013
And what does fine mean??, you asked if it could be in the column well that's where it starts, start from park pull it to reverse and go under the truck and see if it is fully in the reverse detent, move the lever by hand and if it's snaps then you're not fully in gear, do this with every gear to verify that it's not the linkage, this is easier done with two people..Had the linkage checked, it was fine
