GXPWeasel
- Nov 5, 2019
- Kansas
- Greg
- 1982 | 2015
- Sierra C15 | Silverado Z71
- 5.0 | 5.3
Like the title says pretty much..
Got the truck running and verified I got forward (all 3 gears) and reverse while on jack stands. Went ahead and took it for a quick spin around the block. Once I got back, the truck wouldn't back back into the garage. The drive is slightly up hill, and it just wouldn't go. It will move the truck in reverse in the shop (on flat ground) but definteley won't back up a slight incline. I get all 3 gears in forward no problem.
A little back story, I just rebuild everything on this truck, except the transmission. It's a TH350, and I did drain, add the trans go shift kit, replaced the filter, and filled her up. I haven't done anything else to the transmission at all. It has sat for 10 years or so since moving, so I'm sure some seals are dry and need some lube. I know for a fact the shift shaft seal is gone, and I need to replace that. But I'm not touching that until I for sure get a good working transmission.
Any ideas?
Any ideas?
