rdonahe
- Apr 23, 2017
- WA
- Roger
- C10
Hi All,
I'm new here and generally new to GMs. I bought a '79 Silverado w/182k miles, pretty sure original TH350 transmission. Drove home around 20 miles with no issues. In city, highway and stop & go traffic. Drove it some more around the neighborhood that day and transmission started slipping in all gears.
Shut truck off to give it a think, started it up again and transmission worked fine. At first I thought maybe that was a coincidence but the pattern continued for a few more test drives, each time the distance it would work well was less.
Trans had fresh fluid in it by the look of it on the dipstick and it was overfilled somewhat.
Pulled pan and here's what was lurking in there:
Looks like clutch friction material. Here's how the filter looked:
Sooo, I put a new filter on. Put 24 oz of Lucas Transmission Fix and filled the rest of the way with new ATF. I have put roughly 40 miles on it since buttoning it back up and trans shifts fine. Am I sitting on a failing transmission?
Thanks in advance,
-Roger
Thanks in advance,
-Roger
