th 350 stall size????
I'd say they are right. Get one on that range, and you're likely to get in the higher side of scale with the weight and tire size. Although, I do keep forgetting you're running 5.13's. That will sure compesate for some tire size and weight.
jsk1978
ga
shawn
What do y'all think of monster should I go with them or do you recommend some one else????
Monsters scare me.
jsk1978
ga
shawn
Sorry bout that I meant monster trans.
hahaha, yeah I know what you were talking about. Now you're still talking about a converter right? Monster is likely getting their converters from someone else, so they are marking them up. Are you willing to have one shipped to you or you want to pick it up local? Those Recon converters will work well for you, or a guy in CA will custom make one for you to order. He is Edge Converters in Northern, CA. You tell him all your specs, the purpose and what you want out of it, and he'll build it. All the good **** will be in it, it will be furnaced brazed, as does Recon with theirs. I trust Recon converters. They do alot more to theirs than many will do. They use state of the art technology and equipment to make sure they are cut square and true, along with balanced.
rogueakula
