temp gauge problems
bjmoore
Tennessee
Billy
My temp gauge stays pegged all the way over past hot as far as it can go. Was wandering if anyone has any suggestions before I tear into it. I have unplugged it from the sending unit makes no difference. Thanks guys.
Georgeb
Wisconsin
George
K10 Burb Z71
Starting at the sensor work your way back looking for a short to ground in the sensor wire. A short to ground causes a pegged needle.
87scotty
Central il
Andrew
V20
5.7 for now
Yep^
bjmoore
Tennessee
Billy
Ya I think I may be opening a can of worms. Got to looking a little deeper. The interior lights don't work when I put a bulb in the one under the dash, and it worked fine until I turned the steering wheel to one spot and it acted like it shorted out. Arcing noise from around the column.
Well, open that can of worms then and find it. It's worthy of finding and fixing. It might take a bit.
But true, yep your green wire to the gauge is grounded out somewhere. Hope it's the green wire anyway and not in the printed circuit of the instrument cluster. Usually not a hard fix. The most common places is, the wire gets burnt to a header or exhaust manifold, and then right where the wire goes through the firewall. The grommet sometimes wears, cuts or falls out and then the wire rubs on sheet metal.
And just a tib bit test, it can also be a failed temp sender in the head. To find out, simply unplug the wire from sender, then turn the key on. If the gauge goes to the Zero, then you know the direct ground is a defective sender and it has grounded itself to the head.
Snips71
