tbi to carb
hiltijoe
ny
joe
custom delux
okay guys heres a question .I'm putting a bbc in my v20.im switching to old school hei and carbureted.for hp reasons its currently a 350 tbi ,now whats the best way to adapt the fuel lines to the carb.i know inm going to need a fuel regulator with a return line on it.what have you guys done to make it happen .thanks all
yevgenievich
Viktor
sad
very sad
less sad
Tbi has feed and return. Install a fpr and set up fuel pump to run when engine is turning(can be done using oil pressure switch)
hiltijoe
ny
joe
custom delux
interesting how would that be wired?
burb1085
Lancaster
shawn
That would be a good sticky. I'd like to know how this is done also.
yevgenievich
Viktor
sad
very sad
less sad
Tbi system uses oil pressure switch as a backup power source for the fuel pump in case relay fails. Ecm send the relay a signal for priming when the key is turned on. So, essentially there is no change needed when installing the carb if the ecm, relay, oil pressure switch and their wiring stays in place.
ECM will prime the system, and the oil pressure switch will keep the 12v supplied to the pump while there is at least minimal oil pressure. You can also just use the oil pressure switch, which would be about same as if using the mechanical fuel pump. No fuel untill cranking. Not an issue unless vehicle sits long enough for bowls to dry up.
However, I only used the setup with priming ability in tact. As a backup, a toggle switch can be installed in case oil pressure fails but still need to keep going. Or need a longer prime to fill the bowls.
Ideally the fpr and its lines should not be right above the exhaust
gpmorgan
Tupelo Ms.
greg
Yes, leave all wiring as it is to the fuel pump circuit. I installed by-pass regulator and fuel log on a duel line holley.
the bottom line on the reguator is the return.
gpmorgan
Tupelo Ms.
greg
This is the same setup on bbc in the same truck.
hiltijoe
ny
joe
custom delux
sweet that what ill do thanks!!
hiltijoe
ny
joe
custom delux
so the line coming in goes to the fuel log and then to the regulator?
hiltijoe
ny
joe
custom delux
shouldn't the pressure be regulated before entering the fuel log?
gpmorgan
Tupelo Ms.
greg
Yes, fuel enters log, goes past carb inlets, through by-pass regulator, and then returns to tank. Ran it that way for 13yrs. It was installed per instructions. There is also a fuel pressure guage on the reguator. I ran it at 6lbs for the carb.
hiltijoe
ny
joe
custom delux
great thanks
gpmorgan
Tupelo Ms.
greg
Standing in front of the truck, it should be the right line. The larger of the two. Look at your filter and follow the line from it. Mine is a 92 but I think yours is the same. Your filter is on the drivers side (left) frame. Correct?
TrivTen
