Talgate window seal install
BR@NDON
Brandon
V10 Surburban Silverado
5.7 TBI
I am replacing the window seals on my tailgate and am stuck on installing the inner seal which attaches to the plastic trim piece that fixes to the inside of the tailgate. The factory stapled through the sheet metal seal into the the plastic trim, however I don't know what tool to use that will staple through the sheet metal that the seal is made of. These aren't your normal staples, they are extremely "heavy duty".
Any suggestions?
chengny
I don't know anything about Suburban rear gates so I'm flying blind here. Could you drill pilot holes in about the same spots as where the staples were and then pop-rivet the seal to the sheet metal?
A couple of photos might help.
That is a great idea.
chengny
Maybe use those plastic pop-rivets with the wide flange to prevent the seal from developing dimples at the rivet points. You'd want it to lay flat.
MadOgre
NA
NA
NA
NA
NA
Are you sure its stapled through the sheet metal. Its supposed to be stapled to the plastic panel.
BR@NDON
Brandon
5.7 TBI
The window seal itself is metal. That seal is stapled to the plastic. I drilled an old piece of window seal and pop riveted it to a broken piece of plastic. The first time it cracked, the second time it worked because I popped it from the plastic side. I am going to work on it some more this weekend and will post pictures later to show it.
I need to take a look at those plastic PR's because I won't be able to pop it from the plastic side on the gate piece due to the nature of the piece how it curves around etc. I don't know if I am describing this correctly, but I hope it makes sense.
Use a flat washer on the rivet to keep the pressure from breaking the plastic.
BR@NDON
Brandon
5.7 TBI
Longer pop rivets were the answer. I forgot to take pictures along the way, but this is the piece after it's back on the truck. Thanks for the help and ideas here.
Snips71
