Taking out heater core
Jarhead79
Mt Vernon il
Michael
Is removing the heater core difficult, found out that I have a leak under my dash and pretty sure it's the heater core or the eVap core. Doesn't smell like antifreeze but I've noticed my level of coolant is down to just below the heater core inlet/outlet hoses that feed into the radiator.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Its not very difficult. You have to disconnect a couple of cables and vacuum lines on top of the heater box and disconnect a couple of vent tubes. The worst part is getting the mounting bolts that go through the firewall, some of them are kinda tricky to get to, but its not too bad.
Georgeb
Wisconsin
George
K10 Burb Z71
The bolts that are going to give you trouble are hidden behind the inner fender. It's my opinion that dropping the inner fender down or taking it out makes the job a lot easier. Its really only a hand full of bolts.
good times
thorsby alberta
lorne
The biggest problem I had was finding all the screws that hold the heater box together. There were a few hidden under foam seals.
Sent from my SM-G870W using Tapatalk
aaron06
