tachometer
Brandon_l1000
Tennessee
Brandon
350/sm465/np205
hey guys was wondering if you all could tell me how to hook up a tachometer in my truck. its 79 k10
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Red to ignition hot, black to ground, tap the white into instrument lights (headlight switch is the closest tap), and green goes to the "TACH" connector on the distributor, beside where the big red wire goes in the side of the top of the cap.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Factory or aftermarket?
Either one is going to pretty much be the same. Most aftermarket tachs have 4 wires, white, black, green and red.
Red: 12+
Black: ground
Green: distributor - most caps are marked "TACH" and that's where you plug it in.
White: illumination - to the dash lights.
J Knight
Baytown TX
82 Chevy
350ci
A tach will have 4 wires.
power=to swithed hot
ground=to fire wall
light power=to dash light curcit
dist lead=to dist, plugs in right next to dist power lead, its labeled "tach" on the cap.
Hope this helps.
Brandon_l1000
Tennessee
Brandon
350/sm465/np205
and it is aftermarket i bought the set and my dash has the two big holes in the middle and the smaller ones on the side. well the two bigger holes are for the speedo and the fuel. The set came with a big tach and speedo then the fuel level is a smaller one. if it werent for that i wouldn't even bother with it. lol ll never use the tach. I know where to change gears in my truck, i can listen and do that lol.
SquareInheretance
