switching dana 44 hubs
chevydude
arizona
hunt
k20
Hello i am switching my 6 lug hubs to make them 8 lug and i got to the part where there is a clip on the outside holding the hubs inside parts in. the ring is on the outside and is a pain to get out. I have been unsuccessful so far does anyone have a tip to getting the ring out.
Thanks
elstm3
montana
lynn
V30 crew cab dually
6.2 twin turbo diesel
i use a combination of small flat screwdrivers to get behind the snap ring and a pick to pull it up and out of its groove. they are a pain but after you figure out a trick that works its not too bad.
chevydude
arizona
hunt
k20
Ok thanks. So I have every clip out and the hub still will not come off. Im Not sure what else I need to do.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Make sure you got the clip off the end of the axleshaft. Otherwise they are just tight fitting, you may need to take a couple screws out of the hub dial, screw them into the locking hub flange and use them as something to hold onto to help pull them out.
chevydude
arizona
hunt
k20
ok so I need the hub lock nut puller is a 6 lug or is it 4 lug I forgot which one it is and need to buy one one from checkers. Thanks.
504SquareBody
