Stop Slamming my Door!!
73OLyellow
San Diego
Marcel
Hey guys. Have a 73 cheyenne c20 and I have to really slam the door to get it shut. In order to repair do I have to take the whole door off? Or is there an easier fix? Thanks in advance! !:)
73OLyellow
San Diego
Marcel
Thanks farmer! Would you recommend this? Would it damage the door latch in the future?
Smith
NW Ohio
No
along with that check your door alignment. If your, hinge pins and bushings are wearing out it will make it harder to close
73OLyellow
San Diego
Marcel
Okay I hope its none of that ill try the pex tomorow.
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
SWEET!!!!!! THANKS FARMERCHRIS :cheers:
No it will actually help it last longer. I've done this to 2 of my Burbs and the Peterbuilts at work.
MrMarty51
Eastern Montana
Martin
I finally got hearing aids, now, there is a rattle in the left door of My 93, I will pex them posts, see if that`ll fix it.
I`ve pressed and shoved every part and piece on that door, only time it`ll quit the rattle is when I shove downwards real hard onit.
