Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Exterior > Paint and Body
Become a Supporting Member         Become a Preferred Vendor
Advertisements
User Tag List
Reply
Thread Tools Display Modes
Old 01-14-2011, 06:10 PM   #1
HotRodPC's Avatar
Year: 85
Model: Sierra Classic K1500
Engine: 350/Th350/NP208
HotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond repute
Send a message via Yahoo to HotRodPC
Default Fix Slamming Doors - Striker Door Latch Repair
So how many squarebody slamming doors can you repair for under $3. Anyone want to guess??? I was told about this trick long ago. Finally got frustrated enough today, and I happen to be out and about and dropped in at Lowe's for a piece of plumbing.
This is a 5 foot stick of 1/2 PEX sold in the plumbing dept pre cut. I got it for $1.98 plus tax to a total of $2.14.
HotRodPC is offline   Reply With Quote
Old 01-14-2011, 06:20 PM   #2
HotRodPC's Avatar
Year: 85
Default
So you cut off a small piece of this pex to make a new stricker bushing. I happen to have a Pex cutter tool, but for the purpose of everyone, I used a hacksaw to cut mine, I might also add, a junky dull ass bent blade at that.
This is likely what your striker looks like since the orignal bushing has long hardened and broken then fallen off.
Yes, A cheap junky dull hacksaw is all you need to cut the pex for length.
Old 01-14-2011, 06:27 PM   #3
HotRodPC's Avatar
Year: 85
Default
Cut a piece to size, Probably 3/4 of an inch or so. I didn't bother to measure. I eyeballed it for the sake of saving time. Then cut it long ways either with a hack saw if you are coordinated enough, or get some dikes or tin snips, whatever you happen to have and cut it open length ways.
Old 01-14-2011, 06:29 PM   #4
89Suburban's Avatar
Year: 1990 Chevy Suburban
Model: R-1500
Engine: 5.7L TBI/700R4/3.73 10 Bolt Auburn L-S /Cat-Back
89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future
Default
89Suburban is offline   Reply With Quote
Old 01-14-2011, 06:32 PM   #5
HotRodPC's Avatar
Year: 85
Default
Once you get it cut to where it can open up, simply open the piece and put it around the door stricker with the opening facing away from the latch. Very simple. Now close your door with just a little force and watch is shut nicely without slamming it. If it still does not work, then you have other problems like hinge pins or bad latch.
After you get the pex installed, your stricker will look something like this.
Old 01-14-2011, 06:41 PM   #6
HotRodPC's Avatar
Year: 85
Default
Its a very easy cheap fix. So whoever is good at math. How many squarebody slamming doors can you fix with a 5 ft stick of pex for less than $3???
What??? Did you think this was a how to fix your door thread??? It wasn't. Its a test of your mathematical skills !!!
Old 01-14-2011, 06:51 PM   #7
Old77's Avatar
Senior Member
Year: 1977/1987
Model: C10 longbed/R20 Burb
Engine: 350/454
Old77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond repute
Default
Interesting!!! I'll have to give that a try...
__________________
**I hope you enjoy the randomly placed trees and poles in each of my pics **
Click for '77 Build Thread
Click for '87 Build Thread
Click for GMT800 Seat Mod Thread
Instagram: 07burb
Old77 is offline   Reply With Quote
Old 01-14-2011, 08:37 PM   #8
skysurfer's Avatar
skysurfer
Senior Member
Year: 1989 Suburban
Model: V2500
Engine: 5.7/TH400/NP241C
skysurfer has a reputation beyond reputeskysurfer has a reputation beyond reputeskysurfer has a reputation beyond reputeskysurfer has a reputation beyond reputeskysurfer has a reputation beyond reputeskysurfer has a reputation beyond reputeskysurfer has a reputation beyond reputeskysurfer has a reputation beyond reputeskysurfer has a reputation beyond reputeskysurfer has a reputation beyond reputeskysurfer has a reputation beyond repute
Default
I never knew there was supposed to be anything there. I've adjusted that striker every which way and still have to slam the doors. Is it possible to pull the strike pin all the way off so the pvc isn't cut? I don't want to loosen it too much and hear something go "clink" as it falls into the bowels of the sheetmetal.
Oh, I should mention a piece of nylon string cuts pvc pipe about as fast as a blade but leaves a nice smooth edge.
skysurfer is offline   Reply With Quote
Old 01-14-2011, 09:19 PM   #9
89Suburban's Avatar
Model: R-1500
Default
So the extra thickness on the door striker doesn;t affect the latch operation? Did ya have to adjust anything after doing that HR?
Old 01-15-2011, 12:12 AM   #10
HotRodPC's Avatar
Year: 85
Default
To be on the safe side and risk losing the stricker, I wouldn move it at all if its tight already.
I don't see anyway to remove the striker to slide it over anyway. I'd imagine its posibble, but I didn't want to move striker at all. As far as adjustment, I didn't do a thing other than place the pex over the striker as pictured and its working absolutley lovely. I now even feel a nice crisp snap when I hit the door button to get in the truck. This little cheap fix will make you think you are getting in and out of a differant truck.
Old 01-15-2011, 12:18 AM   #11
Old77's Avatar
Senior Member
Year: 1977/1987
Engine: 350/454
Default
Do you think there'd be a way to paint it so that it doesn't stand out so much?
__________________
Instagram: 07burb
Old 01-15-2011, 12:37 AM   #12
HotRodPC's Avatar
Year: 85
Default
Sure if you wanna. But its not much differant than factory. Most don't even realize there is supposed to be a bushing on it in the first place. They come from the factory that way. Really, its not even noticeable.
Old 01-15-2011, 12:40 AM   #13
Old77's Avatar
Senior Member
Year: 1977/1987
Engine: 350/454
Default
You don't think the white on a dark blue paint would stand out?
__________________
Instagram: 07burb
Old 01-15-2011, 12:41 AM   #14
HotRodPC's Avatar
Year: 85
Default
Guess so if you painted your strickers when you painted the truck. But, really I don't think it'll bother you. Won't know until you try it.
Old 01-15-2011, 12:50 AM   #15
Old77's Avatar
Senior Member
Year: 1977/1987
Engine: 350/454
Default
Well, I'll try it and see how it goes. The paint would probably end up wearing off
__________________
Instagram: 07burb
Reply
Bookmarks
Tags
door latch repair
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Glove Box Latch 73-87 (91) Chevy GMC Trucks HotRodPC Interior 81 06-07-2016 08:03 PM
A good source for online repair manuals RetroC10Sport Tech Discussion 14 02-01-2012 11:57 PM
Body Repair Panels for Square Boxes 89Suburban Paint and Body 22 12-30-2010 02:12 AM
Door swap norcalboris Paint and Body 6 09-03-2010 05:21 AM
