stock height with 31x10.50 wheels
Mmoore031908
Henderson, NC
Max
Hi everyone. I wasn't sure what category to put this thread in so it's here cause it is mainly about the tires. I just bought a 85 k10 with a 4 inch lift and 35s the previous owner didn't know he needed to regear the rear end so he was running the stock 3.08s with the 35s. I am wanting to go back to stock height maybe a 2 inch lift with 31x10.50 or something very close. I wanted to some pictures of you guys set up with close to stock height and tire size.
timthescarred
Carson City NV
Tim
Not the best picture, but here is my '83 stock height 31x10.5x15 tires on stock rally rims
marks86
Latham, NY
Mark
12v Cummins
just a heads up 31x10.5x15 was an option from the factory
marks86
Latham, NY
Mark
12v Cummins
I did not know that. Mine is the 235/75r15
thats what my truck came with, but when I bought a 88 k5 it said it right in the glove box factory 31x10.5x15
Mmoore031908
Henderson, NC
Max
tim and john both of those look good thats exactly what im going for.
MadOgre
NA
NA
NA
NA
NA
why do you wanna ditch the 4" lift ? just curious
Mmoore031908
Henderson, NC
Max
I dont have the ability to install the correct gears for the 35s it is a total dog with the 305 off the line. Its got 3.08s with 35s
Mmoore031908
Henderson, NC
Max
I would love to keep the 35s and the 4inch lift. I think it lloks great.
Eh, if you can install (or remove in this case) a lift then you shouldn't have any trouble replacing both axles with a set that have the gears you want. What trans do you have?
Mmoore031908
Henderson, NC
Max
I could probably do it but how much a set of axles be? I have a 700r4 transmission.
Mmoore031908
Henderson, NC
Max
Do they make a k10 axle with a 4.11 ratio? I think ive heard the k20 has some that are 4.11.
MadOgre
NA
NA
NA
NA
NA
Ya with the 700r4 you definitely don't wanna over do it with your tire size. I think with 3.08s youd be looking at 28.5 inch tires to keep that tranny happy.
I personally would keep the lift. As well a 4" lift is just perfect for a daily driver with not to much serious off roading. with 4" your steering works out right, you don't have to extend any drive shaft lengths, keeps the drive line angles nice for longevity, keeps truck close enough to the ground to avoid towing issues, heck you don't even need extended brake lines. And it drives quite nicely down the highway compared to taller lifts. You can keep your stock swaybar with out any modification
Plus its really nice not having to jack up your truck just to do an oil change.
I have a 6" lift and I don't do to much crazy off rod stuff anymore and ive been seriously considering dropping down to a 4" just to fix the steering and drive line angles. and make it more of a factory style truck
I personally would keep the lift, put some tiny tires on there for now, and look for some 3.73-4.10 gears in some 3/4 ton axles, 1 ton if you wanna go crazy on the trails.
Way easier swapping out some axles then changing and settin up gears.
Im running 3.48s on 33s with a 700r4 but im looking for a set of 3/4 ton axles with 3.73s to run the 33s on
35s you definitely want at least 4.10s
MadOgre
NA
NA
NA
NA
NA
ya from what I can find factory gears for 10, 12 and the 14 bolt SF 9.5" was 4.11s not 4.10s
But the 14 bolt FF 10.5" used 4.10s
all were available with 3.73
88SQDRW
