stock 12 bolt shim or crush washer
yevgenievich
Viktor
sad
very sad
less sad
Did stock 12 bolt use a shim or crush washer on the pinion yoke? Trying to figure out what to do regarding driveshaft being a bit too short
MrMarty51
Eastern Montana
Martin
It might depend on the year the 12 bolt diff is from.
For Me, it seems I always get the crush sleeve squished down too far, so then, I add a shim to make up the difference.
If the drive shaft is too short, that has nothing to do with the yoke being a crush sleeve or shims, that has to do with either the differential has shifted back or someone replaced the differential with something that may not have been A1 compatible.
yevgenievich
Viktor
sad
very sad
less sad
Driveshaft too short because rear end was swapped from 12bolt with 3r style yoke to 1310 style 12 bolt yoke. Thinking of swapping pinion yoke to 3r style as it adds length
yevgenievich
Viktor
sad
very sad
less sad
Thinking of also doing flip kit in the rear to solve length issue
millernf
