Steering slop at firewall
Mike7ftr
Fresno
R30
It's like I'm missing a bearing or brushing. I tried to upload a video to show how much slop but couldnt figure out how. It's an easy 3/16" or so.
Mike7ftr
Fresno
R30
Think it's the "lower bearing". Ecklers has it for $45.00. Is there anything else I should address while I'm doing this fix.
yevgenievich
Viktor
sad
very sad
less sad
Depends how far you want to go down the 'while I have it apart" hole. Can change to the Jeep shaft for a small improvement. Some columns had bushing in that area, while others had the bearing
Mike7ftr
Fresno
R30
I've already done it. Got rid of the rag joint.
Mike7ftr
Fresno
R30
I'm wayyy down in that hole!
yevgenievich
Viktor
sad
very sad
less sad
Worth checking the steering column it self. Make sure top bearing is good and tilt attachment is tight
73c20jim
Tombstone, AZ
Doing a little research you can get that for cheaper.
Snips71
