Steering Gear Box
jgasca
New Mexico
Jose
k1500
Ok so i had quite of a bit of play in the steering and I couldn't tighten the gear box anymore or the steering would get stuck. I was told that I needed a new steering gear box.
I went to the salvage yard and bought one for $45
I just took mine off and the shafts dont match. Should I just scrap it and buy a new one or is there any way to save this one?
I tried opening mine up to hopefully remove the shaft and swap them but I had no luck
This is the one I got from the salvage yard
Any thoughts?
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Looks like you just need an older pitman arm.
Or is that from a 2WD?
jgasca
New Mexico
Jose
k1500
it might of been from a 2WD, and I do have the arm that i think your talking about but I dont think it will work
RetroC10Sport
Jay
pontiac aztek
2WD will NOT work in a stock 4WD.
BLAZER/JIMMY (full size) 80-82 Power Steering; 4x4
BLAZER/JIMMY (full size) 83-91 Power Steering
CHEVROLET 10 PICKUP 80-87 Power Steering; 4x4
CHEVROLET 20 PICKUP 80-88 Power Steering; 4x4
CHEVROLET 2500 PICKUP 89 Power Steering; VIN models "R/V", 4x4
CHEVROLET 30 PICKUP 80-88 Power Steering; 4x4
CHEVROLET 3500 PICKUP 89-91 Power Steering; VIN models "R/V", 4x4
GMC 1500 PICKUP 80-87 Power Steering; 4x4
GMC 2500 PICKUP 80-87 Power Steering; 4x4
GMC 2500 PICKUP 88-89 Power Steering; VIN models "R/V", 4x4
GMC 3500 PICKUP 80-87 Power Steering; 4x4
GMC 3500 PICKUP 88-91 Power Steering; VIN models "R/V", 4x4
SUBURBAN 10 80-88 Power Steering; 4x4
SUBURBAN 1500 80-91 Power Steering; 4x4
SUBURBAN 20 80-88 Power Steering; 4x4
SUBURBAN 2500 80-91 Power Steering; 4x4
Dodge will also work...
DODGE 100 PICKUP 80-89 Power Steering
DODGE 150 PICKUP 80-93 Power Steering
DODGE 200 PICKUP 80 Power Steering
DODGE 250 PICKUP 81-93 Power Steering
DODGE 300 PICKUP 80 Power Steering
DODGE 350 PICKUP 81-93 Power Steering
DODGE 400 PICKUP 80 Power Steering
DODGE 450 PICKUP 81 Power Steering
RAMCHARGER 80-93 Power Steering
TRAIL DUSTER 80-81 Power Steering
But the ratio is different.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Bottom steering box is indeed from a 2WD. And, sorry to say, you cant use it.
Nope, Nope, Nope. Will the salvage yard take that 2wd drive unit back? I'd hate to see someone wasted $45. ORRR, just hold onto the 2wd box for a crossover steering conversion someday if a big lift kit is in the future plans cuz the only time you need a 2wd streering box on a 4x4 is if you're doing crossover steering.
RetroC10Sport
Jay
pontiac aztek
Yep. 2WD. That list above is what will fit.
(I wonder if the Dodge ratios is faster or slower, myself...)
Oh hell, Dodge parts interchange with GM on 4x4 steering boxes??? Fuggin Bastards copied us again.
RetroC10Sport
Jay
pontiac aztek
:rofl:
THey're both Saginaw made. Even many Fords came with Saginaw boxes.
:rofl:
Yeah, well, I bet the Dodge boxes are slower. Dodge is slow at everything !!! :roflbow:
jgasca
New Mexico
Jose
k1500
I just bought one from a local auto parts store, at least this one comes with a warranty.
I notice there is less play but still more than I'd like. Whats the proper way to tighten the screw on the gear box to minimize the play? or should i even tighten it?
Oh I hate to ask how much that set you back. Nooooo, I think I'd leave that alone. It should be preset from whoever made it or rebuilt it. I damn sure wouldn't do a thing til it's mounted in the truck and you get to see what it's like. Keep in mind, if you have some slop, it may not and most likely isn't isn't in the steering gear box anyway. Sounds like you might need a front end inspection if you're not certain.
crazy4offroad
Curt
K-10
350/SM465/NP205
Since you have a new steering box I would be looking at other front end parts causing the play. Tie rod ends and drag link ends primarily but also check ball joints and wheel bearings.
jgasca
New Mexico
Jose
k1500
all ball joints have been replaced, I was told when I got my truck aligned that everything looked fine...
And I already installed the new gear box and test drove it. Like I said, its much better but I wish it was more responsive when i turn the steering.
Kipps5000
