Static drop for those on an xtreme budget...
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
I've heard the same thing. To use a SawZall instead of a torch or welder for a nice clean cut and not heat to disturb the springs temper.
Yes, temperamental springs are bad...They'll bounce on you.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Spring rate and height should not screw with the ride so much, what kind of shock absorbers do you run? Maybe a set of stiff dampened ones would solve any bouncing issues.
well then, if that's true, i'll be replacing my front leaf springs with steel tubing. i'll just make sure to install good shocks.
that's incorrect, spring rate has EVERYTHING to do with ride quality.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Take pictures.
proddy2008
texas
patrick
silverado 3500 dually
350/sm465/d70hd
:popcorn:
GOBR
Memphis
Nice, I dropped one of my foxbodys like this before........ Had to buy shorter shocks tho.
lepak
