- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
Are you useing a mechanical pump?
Yes. I just got the regulator installed last night and was finally able to tune the idle mix in properly. It starts and idles MUCH better now. I still have a problem wit hit trying to stall out about 3-5 seconds after start though. I'm guessing I also need to do some choke adjustment. It will now stumble and almost die, but then recover and go to the high idle like it is supposed to. Previously it would just completely die and then require flooring the pedal and cranking until it starts.
I might just leave it like it is, since I just bought a donor 1997 suburban K2500 and I'm going to swap the L29 and 4L80E into my 1980 K25.
