Starting trouble after battery swap
Tfg Colorado
Colorado
Pat
I have a 79 k30 with a 2002 t I 350/4l80e. Swapped in a new battery and truck will turn over but not start. All fuses are good. I’m guessing fuel or spark is missing only have experience with carburetor setups. What is my next step? Thanks Pat in Denver
Camar068
Kentucky
10 yrs Air Force
@Tfg Colorado if it ran right before you changed the battery, check your cable connections at both ends. Make sure you don't have a loose "pigtail" wire connection coming off near the battery terminal.
Scott91370
Burleson, Tx
Scott
Sierra1500
Also check the fuse for IGN and/or Injection. It's not often but sometimes a fuse will blow on older vehicles when you connect the cables.
Tfg Colorado
Colorado
Pat
Thanks for the input. Connections tight, fuses all good. I swapped back to the old battery after a good charge and it fired right up. Very odd
Snoots
Roger
Jimmy Sierra
Have the battery checked where you bought it.
Offrode
