Starting my axle swap 1989 burb to 1986 k10
No I didn't, I just put the single-sided one on to keep the tires in line, for when I rolled it out of the garage. The one I'm gonna use is getting sanded and painted. Maybe I shoulda said "almost ready". My bad.
Question for you guys, are backing plates side specific?
Yes, backing plates are side specific. Things like your E brake cables routing thru the plate would be pointing to the rear of the truck instead of the front of the truck if you used the wrong ones.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
I was referring to the front. I think I might have gotten them mixed up.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
Got the front axle installed on truck.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
Looking just fine. Can't wait for you to take it for a drive and see the difference of 3.08's and 3.73's. Even though it's just under 3/4 turn difference you should still see a bit more pep.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
Almost ready, gottta put the stabilizer on, bleed the brakes, adjust the bearings, Grease all the joints, and it should be ready for a Saturday night cruise.
Driver4r
Nebraska
Trevor
k10,c20
Ahh, sorry to jump the gun, i was partially being sarcastic.
Looks good, hope mine looks like that some day.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
Well, my axle swap is complete, I took it out for a spin this morning, and all I can say is "WOW" what a ******* BIG difference! Its almost like I got an extra 100 horses under the hood. My launches are felt, got on the freeway, and my passing abilities have improved drastically. My speedometer is way off, but I can live with that till I figure out how to change the gears in the tranny. Its funny, but Its almost feels like my truck actually said "Thank you"! I would like to thank everyone who helped me out with advice and knowledge, Hotrod, Driver, and GM SQUAREBODY!
Driver4r
Nebraska
Trevor
k10,c20
Your welcome. Now just try and keep the tires on the rims XD. :rofl:
Driver4r
Nebraska
Trevor
k10,c20
I cant wait to find a set of 35's for mine. Then down the road i want to regear to 4.88's
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
Pep? after todays test drive, my truck it actually has a nut sack now! Big difference! the rear Eaton locker works really good too! Makes me wanna go make a burn-out vid.
:grd: :waytogo:
Just keep in mind, they are 10 bolts. With those big tires and the locking axle, to spin both those bigger tires on pavement, is putting a pretty good stain on that rear axle. The Eaton G80 Gov Lok, get's it's nickname, Gov-Bomb for a reason. I'd consider them light to mild duty axles. If you have OEM tire sizes you could probably get by with some horsing around on dry pavement, but with bigger tires, I don't think I'd get to aggressive very often on dry pavement. Wet pavement, gravel, dirt or mud road would be a different story and should be able to hold up to a little bit of reasonable fun.
Driver4r
Nebraska
Trevor
k10,c20
Who knows, i might have been lucky, but my 12bolt 4.11's with the g80 would doo a pretty good burnout leaving school XD XD. Exspecially on 32x11.5-15's. And a higher first gear.
bigcreek
