JRandle
- Apr 18, 2014
- Verden, OK
- Jesse
- Chevrolet Silverado
So here's the problem and the reason I'm still unable to drive my truck!
The outside hole for the starter on my block has been drilled bigger and used to have a helicoil in it but I don't think another one will work... So here are my solutions I just need to know if it will work...
1- JB weld the hole and drill and tap it back to the stock hole size.
2- Grind the top of the ear hole and put a longer bolt and a flat washer and nut on the end.
3- I found an adapter that will bolt to a 700r4 to make a bell housing bolted starter work.. And I believe I have found a starter that will work also.
Let me know what yall think!
Sent from behind you.
