SRW to DRW
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
I geuss i wasnt really thinking the lockout sticks out quite a bit on a 10 bolt maybe it would be close to flush with the rim if you used adapters
My dad had a K20 he converted back in the 80's, I don't know any of the specifics, but you could turn the lockouts without tools. Until one of them broke and he just rode around with all the parts in the gloves box and assembled the hub whenever he wanted 4x4 lo.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Here's a shot of my K30 when the bed was off. You can see the springs are closer to the frame and the shocks mount on the inside of the frame.
Also, here's a link to a company (Arrowcraft) that makes dually conversions. They've been around for over 30 years. Unfortunately, they don't make squarebody fenders anymore. Unlimited Products makes square body dually fenders. Part # GM-201R/L.
http://www.arrowcraft.com/products.php#fenders
http://www.up22.com/chevytruck.htm#GM-201R/L
so if your stock spring perches are like that, your chassis was originally a srw 1 ton? what about CUCV trucks? did they come with the same setup?
this is my setup, so I guess I technically have a srw 1 ton chassis...
The easiest way to tell at a glance is the shock location. 1 tons are inboard of the frame rails. They are also staggered in the opposite direction as 1/2 and 3/4 tons.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
yes the shocks are just inside the frame rails...
guess I have a k30...maybe kinda
makes sense with the CUCV rating at 5/4 ton
SA Fan
Johannesburg, South Africa
Marius
Wow, thanks guys, a whole mouth full of info. I've seen the Arrowcraft kits on the net but they are quite pricey. I was hoping to find good used parts. Is the price of $300 for the spacers for K20 or K30 spacers? I think I'll be able to fabricate different rear spring hangers.
The spacers should fit either axle, since they just bolt onto the factory wheel studs. When GM built a DRW truck, the "spacer" was cast right into the hub. Nowadays, the OEM's just use spacers.
CSFJ
Your k30 should already have the correct hangers.
SA Fan
Marius
Thanks for all the input, much appreciated. Any ideas where I can maybe find used spacers as well as used wheels and fenders. Unfortunately the exchange rate of the US$ versus ZAR is not in my favour at R14/$ and I need to try and save where I can especially because I have to still ship it halfway around the world as well. There must be squarebody junkyards around that you knowledgeable guys can recommend.
ajd89
Central Michigan
andrew
Ive got 6 dually rims tires are pretty much junk id sell them but probably gonna cost an arm and a leg to ship...
Jrgunn5150
Ionia Mi
J.R.
6.slow
Just FYI, Fastenal does pretty reasonable shipping. Guy who bought my 406 used them and they sent it to Atlanta for like 140 bucks or something.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
So my 1 ton
damn it I’m gonna need some why is everything so far?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
See this is where we get big chips plane! Lol! Ill tell you what ill roll them south and hope they make it...its all down hill right?
Lol I’m reserving that service for my Zonkey. ain’t that right @Big Chip ?
1977chevyc30
