Matt69olds
- Jan 8, 2018
- Central Indiana
- Matt
- GMC 1/2 ton
- 455 Olds
That’s a cable driven speedo. Unscrew the cable, make sure the plastic gear inside turns when spinning the driveshaft. If not, most likely one of the gears has stripped. If it has stripped, don’t replace it until you have inspected the cable. If it’s tight and hard to turn, either lube it or replace it. The gears are different colors, with different tooth counts to calibrate the speedo.
