Dutch Rutter
- Aug 13, 2013
- Independence, Or
- Joshua
- K20
New yet annoying issue. The Speedo needle has started a bounce, I only see it at lower speeds, and only when just starting to drive the truck for the first 10 minutes or so. When slowing to a stop, the needle falls not a smoothly then bounces back up a few MPH. then when It should be zero it bounces up to 40 then falls back down to zero.
I've also noticed a faint metallic "tinging" at low speed. Kind of like a sprung spring or metallic teeth slipping. Could be unrelated I really have not idea.
Where should I start looking into this? Gauge, cable, T-case, or cable adapter for tire size.
FYI, just moved into the new house so tools are still buried in other packed things.
