Spark plug wires...
cooter55
Placitas, New Mexico...not really New...not really
Jack
C20, R10
454FI, 350
This could be the most anal question ever asked, but here it goes. When I got the '73 C20 with a 454 the PO had put on a mix of anything goes spark plug wires. I recently got a set of "cut to length" wires. I can do the trial and error method of figuring out which length is best for each plug run, but does anyone know what the correct wire lengths are for each specific plug?
350runner
tx
Ceasar
Shorter the better:)
350runner
tx
Ceasar
Long wires= long runs. And so on. It really is up to you. I don't show my engine off cause it don't look like what you expect with the short wires :).
Skweegle89
Oklahoma
I assume the longest go to 1 & 8 etc
GTME94
Metro Detroit/Holland, MI
Terry
C2500 C6P Camper Special
454/TH400/14bff 3.73
A pre-made set is probably a compromise in one position or another depending on a lot of things like exhaust manifolds, etc. They may also be made to fit several different applications but none perfectly.
The best thing to do is route them as short as possible while making sure they don't get burned or rub on something.
MadOgre
NA
NA
NA
NA
NA
If you want it to look nice, your best off getting the crimper and making them your self to the proper length for your set up.
The pre made sets are universal all of them are made to fit any possible way out there so they are universal even when it says custom
Start with the longest wires and work your way down starting at the furthest plug from the distributor. Take the time and use a magic marker to number all the **** on the cap with the correct cylinder number and firing order, that will help lessen any confusion or mistakes.
highdesertrange
kalifornia
mike
k30
number 2 is the longest. number 8 and 7 are the shortest. put those on and it should be fairly easy to figure out the rest. this is under the assumption that the distributor is in correctly. highdesertranger
Chype1
