spark plug pictures diagnostic thread
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Have a spark plug? Take a picture of it. Share it here.
Explain why it looks the way it does or ask why it looks the way it does.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Oil fouling. My valve stem seals are not good.
Shorty81
Baby Boomer
North West ohio
Darren
Just pulled these out. Very happy with how they looked. The old BBC is happy. Very consistant.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
#6 & # 8 plugs after around 4K. Presumably weak piston rings from being right beside the EGR.
Could be bad valve stem seals, but since it smokes until warmed up, AND my hot rod mechanics told me the passenger bank is the weak side, I suspect it is not the better of the 2 possibilities.
78C10BigTen
pennsylvannia
C10 BIG TEN
Mmm oktoberfest!
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
Mine smoked at start up. #7 plug was fouling. Got the valve stems replaced, no more issues.
Lean condition.
Also mismatched gaps
Also a bad coil to cap wire. The nub on coil is worn down so it arcs it over time probably not strongest spark
Backfoot100
Florida
Eddie
C1500 Suburban
Carbed 350
#6 is oil fouled after 5k miles. Had some smoke on startup since I owned it. Compression test is 165-175 across the board. Very happy with that.
Just finishing complete valve seal replacement with all positive seals. Factory seals were rock hard. Surprised this is the only plug that looked like this. All the rest looked perfect.
Guess I'll see if that fixes it.
Take it out to I-16 and blow the gunk out.
aaron06
