Smog Pump and Egr valve delete
K5Blazerboy87
Tacoma Wa
Kyle
K5 Blazer Silverado
Hi guys i took the old engine out of my truck im putting in a 350 crate in its built more aint stock i got from west coast engines i wanna get rid of smog pump was wondering how can i with out engine running bad i wanna keep the tbi system i know there is air injection valve plugs in if it would make computer or make engine run funny or not good. Would it be worth deleteing egr valve if i delete smog im really just want my new engine run good i hate having emissions crap cause i dont need it no more.
The smog pump can go, along with the lines to it.
I personally don't care for egr valves, but if it's working on an existing engine, I'll leave it. If it fails, I'll delete it. If I'm putting a motor together, I won't bother with installing one.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
I ditched my air pump and all of the emission crap long ago. No issues since.
K5Blazerboy87
Tacoma Wa
Kyle
K5 Blazer Silverado
Like egr valve too
T-ROD
Shelbyville, Ky
Travis
I don't have anything from Catalytic converter to the smog pump, no get either, I have A 74 intake though, it doesn't have the spot for it, it runs real nice, it's just that if your into quadrants, they are very much a PITA to get just right, I mean literally, It took me a couple years to get it right, they are usually designed for factory setup and vacuum response, mine idles at about 955 RPMs but good enough, it has a mild cam, and I still have the evaporator can, and quite a few other components that are slightly needed, but it should be fine other than with TBI (which is one of my favorites) you may need to put a resistor inline with where solenoid once was, about 75-100 ohm, or it will probably go into limp mode without vacuum solenoid, and of coarse the pump can just be deleted, it can effect the fuel output a bit, but not much, it's because the Module is waiting to see more oxygen from exhaust due to air input through manifolds from smog pump
smoothandlow84
Steve
I removed the cats too...and went with long tube headers and dual flowmasters. The catalytic converters were partially clogged and pieces were rattling inside. In the trash they went.
yevgenievich
Viktor
sad
very sad
less sad
egr should be tuned out, ecm tests it's operation and relies on actual exhaust gas to be recirculated when it chooses fuel and spark tables. It would likely to throw a check engine light
idahovette
Weiser Idaho
Perry
K20-K10
Out here we usually have a guy that comes around wanting to buy our old catalytics that we remove!!
436'd skylark
VT
Joe
2500HD
Durajunk
Yeah you'll need to turn the egr valve off. The ecm throws extra timing in when the valve is open to compensate for the loss of vacuum. For what it is worth you won't gain anything by tossing that stuff. The EGR doesn't operate under WOT and the air pump is harmless.....
smoothandlow84
Steve
Out here we have people take the time to sneek around at night and cut them off from under the car
But the EGR valve does recycle junk into the intake. Other than that, yeah, it doesn't hurt performance at all.
436'd skylark
VT
Joe
2500HD
Durajunk
It's closed under WOT and you would never know it's open when you're headed to the nail salon for your pedicure.
Trust me i know what it does and how it works. Lots of misinformation out there.
84 k10
US
monty
k10 silverado
Ok so take the belt off smog pump, cap egr or relace with block off plate and see how it runs. If you get good results start pulling vacuum , diverter valves, hoses, and plug or cap what you have too. The so called emissions BS does nothing in my opinion except cause carbon build up, and poor gas mileage. Pull the intake manifold you may be surprised how much build up has occurred where the egr valve port is.
Sent from my LGMP260 using Tapatalk
hayden
Hayden
R10 Silverado
If I remove the air pump and EGR, will the engine run like it should or will it mess with the computer on the TBI system.
JOD26
