- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
Also, the chamber size (around 64 cc) is too small for a 400.
Not all early 70's heads had hardened seats. I had a set of heads that were damaged as a result of unleaded fuel and IIRC, they were 73 Julian Dated heads.
Why do you say it is too small?
Assuming a "stock" 8.5:1 CR, going from the stock 76cc to a 64cc will raise your compression about a full point, to around 9.4:1, on a 400. I see nothing wrong with that. Still fully compatible with pump gas and all the benefits that come with better compression.
And depending on the cam you might even want to go a little higher to get your dynamic compression up to 9.2/3 or at the very least you dynamic compression will be lower than 9.4 which will work fine on pump gas.
I just did the math, and you're right! Guess I had my "zero deck" hat on.
However, pistons with big dishes (22cc-24cc) will need to be used to attain 9.4:1 or less, especially with iron heads.
Check those DCR numbers and you'll find 7.5 to 8.5 is the ideal range for a pump gas street engine. 9.2 to 9.4 would be detonation city.
Not quite. lol
A 9.4:1 SCR engine is probably gonna work out to be about 8.3-8.6:1 DCR Which falls with in your requirements for 8.5:1 DCR to run cruddy 87 octane fuel. Which is what I have already said, in the post that you are referring to.
So my point is valid if you quit nit picking everything I say to death, and actually listen to what's being said !!! Talk about OCD
