Short bed side rust prevention?
olnick
Milford NH
Nick
c15
1982 350 4 bolt mains
I just spent two weeks cutting/grinding /welding/painting on both of my NLA bed sides! Does anyone have a method to treat the inside of the bed panels? and the floor supports? the floor supports can only be accessed 1/3 of the way from each end! How do you treat the center portion? and the other smaller supports? The bed panels are too narrow to get any portion of my arm up in far enough to do any good. The front edge on the psg side took the biggest hit and the arch over the tire on the driver side. both tailgate posts were GONE from the floor down and an inch up!! Now that all is well again I'd like to "treat" as best I can to prevent this from happening again too soon. Has anyone tried drilling access holes inside near the top of the side rails to allow spraying oil Etc. the 3/8 inch ziebart plugs would fit in perfect to block off the holes these would allow access in between the panels? Any and all suggestions will be considered!!
Thanks
Olnick
dvdswan
Port Orchard, WA
Dave
I wouldn't suggest any spraying oil, dirt will stick to it and IMO start the whole rust process all over. IMO you best solution would be to ensure there is at least a primer weldable primer coat to protect the metal, then after welding apply another coat of primer/paint on the areas where it was welded.
I would suggest taking the bed off and putting it on the end standing up, scuff the underside areas with a scuff pad. Prime it and then undercoat every where water would have access too. Since the bed is off you can address any issues on the frame as well.
Eastwood sells a neat kit that allows you to spray inside frame rails up to 2 feet. Check them out.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Eastwood's internal frame coating is pretty good stuff, a little costly, but worth it. Make sure to get a can of pre paint prep spray to clean out the nozzle and hose to be able to reuse it.
Sent from my Moto Z (2) using Tapatalk
omillan99
El Paso, TX
Oscar
K20 Scottsdale
350 4 Bolt
I have zero personal experience with rust but I have heard of people using a spray on bedliner to help prevent rust build up. Not sure if that would be something you'd want to look into.
Donnie
IN.
Donnie
C30
see if there is a Rust check or Krown dealer by you and have them spray it. I just sold an 04 Deville with no rust
that was rust checked every fall.
heres a Krown dealer I found
Gilly’s Auto LLC
603-443-1994
1205 Route 114, Grantham New Hampshire, 03753
trukman1
USA
Gary
K5 Blazer
5.7 L (350)
Sorry I'm a tech moron but I don't know how to make a link "hot" but here's the URL(?) for a good read:
howtosavemoney.ca/which-rust-proofing-service-is-best.
I'm sure someone will know how to make it a link you can click on.
Shows a study conducted by the Canadian Military for rust-proofing vehicles. Note for those in Canada, they say stay away from Canadian Tire, for the most part. Don't live in Canada so not familiar with that company.
I just typed in "Which Rustproofing Service Is Best?" and found it.
trukman1
USA
Gary
K5 Blazer
5.7 L (350)
For a good read on the topic I went to:
howtosavemoney.ca/which-rust-proofing-sevice-is-best.
It shows a study by the Canadian Military comparing top rust proofing companies.
Not saying one is better than another since I have no experience with any but more information can't be a bad thing.
Tried to enter this once already but I guess I wasn't successful on first attempt.
ETA: Of course when I attempted to post second post, the first showed up. Duh???
gmbellew
Kansas city
glen
suburban 1500
I have had my suburban treated with Krown each of the last 2 years. Previously it was out west and had near zero rust when I got it. I figure $150 a year is pretty cheap to keep it without rust problems here in the midwest.
80BrownK10
Greenwood, SC
Nate
What do they spray on it. Is it like actual under coating like rubberized, is it paint or just some oily type product?
gmbellew
Kansas city
glen
suburban 1500
Krown is an oil like product.
ruggedly
