SEAT SPRING REPAIR
echo7bravo
Alabama
Adam
K-10 stepside
350/Th400, 4.56 with 35" BFG MT
Anyone repaired their own springs in the bench bottom? I picked up an 86 K-10 with about 25 busted wires in the seat spring/bottom. The seat foam doesn't look too bad nor does the cover. Was thinking I could get some wire mesh and build my own. Then just put it all back together with some new hog rings.
Any thoughts?????
chengny
Any thoughts?????
As original, the wires that run fore & aft were only twisted at the ends - no hog rings on them:
echo7bravo
Alabama
Adam
K-10 stepside
As original, the wires that run fore & aft were only twisted at the ends - no hog rings on them[/ATTACH]
I'm sorry, I wasn't clear. I meant take the hog rings off the cover and remove it and the foam. I was wondering what if anything anyone has used to repair the horizontal and vertical wire grid that sets inside the coil springs holding up the foam.
yevgenievich
Viktor
sad
very sad
less sad
I had some broken on 94 truck, replaced with wire and added foam. Been fine for over a year so far.
Jonny1981k1500
