- May 18, 2020
- Washington
- Todd
- K20
I discovered the puncture just recently. I say it happened a while ago because my water issue in trunk area is newer because hte last time i had the carpet out was early summer. The issue has fortunately been mostly minor.
but i do like your ideas of fflashing or other patch material.
i am new to home and DIY use of caulking, adhesives(construction), sealants. And how they are not all interchangeable and etc.
I did not realize seam sealer couldnt span gaps. For the firewall, short of welding in new firewall, could i clean up the material and span the gap with a plate of metal, using seam sealer around THAT? I can make a piece of metal plating from an old snowmobile route sign that i can use a vice and put a bend in to contort to old surface. I was thinking clean up the surfaces, paint and seal, secure sign, seam seal, then finish paint beyond boundary of sign?
all this after fixing the origin of the damage(or at least it seems, hah, get it?) in the cowl
@Grit dog for my car, assuming the metal pounds back and there is relatively little difference in gap left, could I just seam seal and protect with paint or do you think it still needs a new backing material?
so is the water coming from the puncture or not?
I’d presume not since the carpet is on top of the panel covering the spare and the hole is under the spare tire.
Either way, yes pound it flat and affix a plate over it if it’s troublesome to you or somehow spraying enough water in to get up to the carpet.
Put a bead of caulking, rtv, seam sealer, epoxy, bubble gum or weatherstrip around the hole. Stick a patch panel, license plate, flashing, sheet metal from a junk car or whatever and rivet or some self tapped screws into it compressing the sealer and you’re done.
Idk what the firewall rot looks like but same concept. Anything you compress under the peach panel will seal better than smearing it around the edge.
Again any of these materials will work as good or better than a $15-30 tube of seam sealer that will be junk the next time you go to use it after the tube is opened. And likely something you already have on hand for free.
Same question though on the firewall. Is it leaking into the truck? Or why does that need fixed? Presuming you’re going for function over form. This is not asthetic body work, right?
