75Monza
- May 5, 2017
- Colville, Washington
- Jeremy
- 1980, 1982, 1985
- K30, K20, K20
Okay, ran across something that I'd never seen before or maybe just never noticed on my plow truck 350. Basics...this is a 350 4 bolt GM Goodwrench motor that was in my 82 plow truck about 10k on motor, PO did some cooling system no-no's and ended up with blown head gasket and warped head. I took it down, checked the bearings, did all the seals on the short block, rebuilt another set of heads I had laying around, just press in studs, not screw in. Just a basic performer cam in it that was fine, re-used it, lifters and pushrods, but changed over to cast roller tip rockers, long slot. I coated everything with break-in lube even though most was not new, never thought about soaking lifters (not sure it even makes a difference) and adjusted the valves on the stand using a 4 rotation individual valve adjustment that I found in a book (my short term memory is shot from many concussions, so couldn't remember how I used to do it) with a degree wheel on to keep track. When I was done, just doesn't seem right. Re-checked and had severe slop at #1 I when it should have been where I adjusted it to.
Someone got a link to the proper hydraulic valve adjustment procedure? Unless there is something else (dread the thought, stud pulling out) think that procedure I did sucked.
