Running a 4" lift and 37s??
Jonesta89
Southern IL/STL
V2500 Suburban
350ci
New to the forum. i have had my 89 V2500 Suburban for a year now. My tires are getting to the point where they need replaced. I can get 37" mt military takeoffs for close to the same cost as the 285/75/16s I have currently. Does anyone have pics or links to another thread with a 4" lift and 37s? Im not opposed to trimming my fenders to fit. Anything is appreciated.
hirschdalechevy
norcal
rich
k-30
Sorry , have no pic's of that combo , I am down with bigger lifts than 4's , I guess you could do it but major cutting would be a factor. You could go a body lift for cheap and make it happen.
MadOgre
NA
NA
NA
NA
NA
What gear ratio are you running? And what transmission?
Jonesta89
Southern IL/STL
V2500 Suburban
350ci
It has 4.10s right now. I planned on swapping to 4.56 or 4.88. The trans is a t400 that has 2000 miles on a rebuild
MadOgre
NA
NA
NA
NA
NA
Ok that will work then.
MadOgre
NA
NA
NA
NA
NA
So with swapped gears a 4" lift with trimming would work? I dont really want to do a body lift to fit them however
Oh as far as the 37s go you will need to do some major trimming to stuff 37s under a 4" lift. You would need an 8" lift to properly clear 37s with out bent fenders.
Jonesta89
Southern IL/STL
V2500 Suburban
350ci
Thanks for the help. Im going to continue reading around. I really do want to run 37s since they are cheaper than 33s and i love the look of suburbans sitting on big tires
jmbcary44
NC
Jon
v1500 Suburban
5.7L 350 SBC
what kind of lift is on it now? block, spring, flip? sell it to me and then get an 8 inch
firebane
Calgary, AB
Curtis
There is a lot of smart guys around here and when those smart guys talk its usually good to listen. You simply will not get 37s under a truck with 4" of lift without some SERIOUS body work.
If you want to run that size of tire then you need a MUCH MUCH larger lift and when you start getting into that you will start having drive train issues elsewhere that will need to be addressed as well.
Don5
West Virginia
Don
k15
I have a 6 inch lift kit and a skinny 37 would be very close. I am thinking a slight fender mod will be needed to make it fit. I don't see how a 37 fits on a 4 inch lift unless you do some major trimming.
Jonesta89
Southern IL/STL
V2500 Suburban
350ci
Im going to continue running 285/75s for right now. I have no lift on it right now. Brand new 285/75s just barely clear in the front fender. I do most street driving and some offroad on mostly flat ground. With trimming and small body lift could I fit 35s?
Green79Scottsdale
G.R. - MI
Bob
Thanks for the help. Im going to continue reading around. I really do want to run military 37s since they are cheaper than 33s and i love the look of suburbans sitting on big tires
Fixed it for ya.
CBidzinski2010
New York
Cody
350ci
I'm in the exact same boat as you bud, bought my 87 k20 advertised as a 4" lift but not 100% sure, it's also has been Dana swapped front and rear and I have 16.5" wheels. Bought 37's for it and they will clear the rear ended fine but the front end is kind of tight. I just ordered 2.5" blocks with longer U-Bolts for the Dana 45 up front and I will let you know if it clears the tires after. The truck sits a little lower in the front now so this should level it out as well.
pic shows you how big those 37's really are
CBidzinski2010
New York
Cody
350ci
These are the 33's
Garcjay
