Reverse light power...
78C10BigTen
pennsylvannia
C10 BIG TEN
If i was to hook up an led light bar under the rear of my truck what wire would i attatch it to so that it comes on with the reverse lights?
IIRC, it's the light green wire.
86Peter454
Missouri
C10 Scottsdale
along this same line.
anyone know where the wire inside the cab is for the reverse lights? (putting in a floor shifter and need to add a reverse light switch. truck was a manual so no column shifter to pull it from)
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Small connector under the column with blue/green wires.
You can see it dangling here in this picture:
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Put it on a switch lazy ass. :D Then you can use it for other things and your truck won’t roll away when you put it in reverse with it not running.
78C10BigTen
pennsylvannia
C10 BIG TEN
When do i ever put it in reverse with it not running? Lol
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
When you’d be using the light for other then backing up. Like night fishing or **** like that and the only way it would work is when it’s in reverse and your e- brake don’t work.
87scotty
Central il
Andrew
V20
5.7 for now
Itd be in gear so not rolling lol
87scotty
Central il
Andrew
V20
5.7 for now
Yea read that after I posted figured you'd call me on it haha i jumped the gun
86Peter454
Missouri
C10 Scottsdale
that the same on automatic column and manual?
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Yep. On an auto column, it plugs into the switch at the base of the column. On a floor shift column, it plugs into a small harness that runs out through the firewall, and then to the transmission.
Dan Brown
Katy, Texas
355 (.030 over 350)
Find the wire that's hot at the light wiring harness at the back of the truck when the vehicle is in reverse, and tap into it. You might want to consider using a relay that the hop wire activates, to send the signal to the light bar.
86Peter454
Missouri
C10 Scottsdale
awesome thanks for the info.
78C10BigTen
pennsylvannia
C10 BIG TEN
After all i just tapped into the hot lead, grounded the other and voila!!
87R10_Cruising
