replacing locking mechanisim on center console 89 sub
Grumpy Grizzly
Kalispell, MT
Josh
Suburban 1500
Ive been trying to figure out how to get the damn thing out to put another one on that I have in my other "parts" suburban
Snoots
Roger
Jimmy Sierra
There should be 4 bolts (or studs) in the bottom.
Grumpy Grizzly
Kalispell, MT
Josh
Suburban 1500
I don't see anything there and I'm just removing the lock itself cause the interior colors are different
Grumpy Grizzly
Kalispell, MT
Josh
Suburban 1500
here we go I have that hole you talk of. I'm assuming that is the way?
Yeah, that little hole is the trick. Iirc, with the key inserted, you stick a paper clip into the hole and it comes apart that way. There's a thread on it here somewhere, it's like the glovebox lock.
Grumpy Grizzly
Kalispell, MT
Josh
Suburban 1500
Well that answers a lot, thank you for that info!!!
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
I don't mean to resurrect a dead thread here..
But I'm trying to remove the center console mechanism myself to send off to someone .. I popped the cap off of the top like he did, I've tried a paperclip in the hole, key inserted, turning the key and prying, thing will not come out!
Slowness on my part...
Looked at hotrod's post... I'll try that and then return....
Thought it was unrelated to center console
mrandle
