Replacing fan motor
83kid
Massachusettes
Hi,
Went to replace my blower fan motor because its tired and doesnt spin too fast...
Put it in and it made a ton of vibrating noise. Also, could see there are 4 shiny rivets on it on the outside with it in, and could see little tiny sparks on them every once in a while.
Took it out, inspected it, everything seems as it should be besides one thing. I used a new motor but kept the old fan. The old motor shaft was a little bit larger on the end, the nut was a bigger size. The new one, its a smaller size but still fits on nicely and tightens up and seats fully. But, the shaft on the old motor does not move in and out. The shaft on the new motor (Went to NAPA and got one for a truck without heat, as mine is) you can pull in and out by hand. This is before the fan even goes on.
Anything suggested to fix this? Thanks!
yevgenievich
Viktor
sad
very sad
less sad
Sounds like the new fan motor assembly might be defective.
83kid
Massachusettes
Got another and it was the same way, so i figure for some reason its made that way
v2500burb
Charlottesville Virginia
Jay
v2500
350ci
My fan motor is missing a speed
I have
High
Missing
Medium
Low
Any suggestions?
yevgenievich
Viktor
sad
very sad
less sad
it would be located on the hvac housing under the hood
tnahaus
