Replaced cluster lights with LEDs
Milblazer
Colorado
MilBlazer
I was tired of not being able to see squat when driving at night so I decided to pony up the cash for some LED bulbs in my instrument cluster. I am more than happy with the results. These lights are visible during the day! There was one spot where the LED bulb had trouble fitting. Also I had to insert the black plastic light holders into the socket and then add the bulb as they wouldn't fit through the back. I think they look pretty good. What do you guys and gals think?
Stroked
Beloit, Kansas
Jared
They look great! This is on my list of things to do this spring.
Sent from my Kindle Fire HDX using Tapatalk
Looks great man. I tried the cheap way out on the LED's and they suck. I will try to get those ones you got.
77 K20
Montana
K20 5" lift
HT383 fuel injected
Looks nice! How much did the LEDs cost? Where did you buy them from?
They do look nice and bright- but do they still dim down nicely for those times when you want the dash almost dark?
They look like the ones they sell at superbrightleds.com.
Hey did you do the turn indicator bulbs too?
chubble
Eastern, NC
Custom Deluxe K10
Looks awesome! On my long list of "little projects" too. It was near the top before someone bought me speakers for christmas.
Stroked
Beloit, Kansas
Jared
I don't think you can dim LED's can you?
chubble
Eastern, NC
Custom Deluxe K10
Not in the traditional way. Your stock dimmer switch won't dim them.
mrnapolean1
'87
4.3 V6
Can you link me to where you got your leds from?
Milblazer
Colorado
MilBlazer
I purchased my LEDs from superbrightleds.com. Cost right around $200 for the just the instrument cluster lights. I did do the turn signal lights as well and they are BRIGHT. These LEDS do dim a little. When I say a little I mean the difference is about the same if you were to stare directly into a head light (no dim) and then put some cheap sunglasses on while still staring into a headlight (dim). Either way it's still pretty damn bright. Overall I think I overdid it just a little and would go with some that aren't as bright next time.
Milblazer
Colorado
MilBlazer
I should also mention that it was suggested to buy a no load flasher relay so the turn signals would work with LEDS. I tried it out without the no load flasher and with and mine worked the same both ways.
UPDATE: I went outside to get a picture of the hazards working to show how bright the green light is and when I pushed the hazard light in I got two steady green lights and no flashing WITH the no load relay I got with my LEDs. I plugged my old relay in and they started flashing like they should. Weird.
Milblazer
Colorado
MilBlazer
Here are the turn indicators. First picture is inside, second is from outside lol
Jeff Dodson
Angleton, TX
Jeff
Sure won't accidentally leave the turn signal on will you ?
3dbello
