- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
And make it a 5 point one as well!
I just had to cut through some frozen control arm bolts on my Tahoe. There is a new Diablo metal cutting blade with large teeth you would swear would only work for wood. Man was I wrong it cut through that 20 mm bolt head like hot knife on butter.
That was my first thought too! It looked like a wood blade. The large tooth version doesn't always work on hardened bolts, it just depends on the specific bolt hardness and metallurgical properties I guess. But they sure as hell saw through everything else right quick!
