Rear drum brake hot and screaming.
ExPatSquareBdy
Bonn, Germany
Volker
C15 Sierra Classic
350 ci
Just did the rear axle. New bearings left and right, new seals, new drums (old ones could not be turned again - 40 years old.....), new wheel cylinders, shoes were still good and re-used. Springs, brace etc. all good and re-used. E-Brake cables good, working and release fully. Adjuster working.
Now - right drum ok and working properly. Left drum getting hot and - when warming up - gives a loud squeaking-growling noise. No dragging or locking up.
All checked and cleaned. Put together again - a few days later - started again. Tried to re-adjust by backing up and hitting the brakes. Worked a few days - then again growling-sequaking noise and hot. Hot enough to not put your bare hand on it.
Checked the parking brake cable. All good. Checked the proportioning valve and bled the system. All good.
Anyone with an idea what may have happened? Should I test new shoes? This would be the last Thing I have not tried yet.....
Any idea is really appreciated.
twinturbo427
Florida
Phil
Suburban
Check your drum and shoe width. Light duty brakes are 2" and HD are 2 1/4". If you were sold a LD drum and put it over HD shoes, it will fit but pinch the shoe when you torque the lug nuts.
Advance sold me two drums, same supplier, same part number...but not the same drums!
Other than a hung/sticky wheel cylinder, everything else I can think of would affect both sides.
ExPatSquareBdy
Bonn, Germany
Volker
C15 Sierra Classic
350 ci
Good Point. It came original with the HD RPO. I ordered HD drums.
OK. Another session....
Only cool point - with opening the drums every three days they`ll never rust-lock. o_O
twinturbo427
Florida
Phil
Suburban
Except lugs and studs are wear items and you have now used 50% of their life!
haha, better buy new studs and keep them handy. (insert a fitting humorous emoji here)
:cheers:
ExPatSquareBdy
Bonn, Germany
Volker
C15 Sierra Classic
350 ci
:cheers:
Lugs and studs are among the few commodities available here in EU.
I'm least worried. :)
highdesertrange
kalifornia
mike
k30
well I never would have changed the drums without changing the shoes no matter what they looked like. I would also check that left drum for being out of round. highdesertranger
ExPatSquareBdy
Bonn, Germany
Volker
C15 Sierra Classic
350 ci
Yeah - changed the shoes this Weekend. Got worse and worse. Now: Silence. :)
xXmutantXx
