Rear disc brakes on the cheap
74 Shortbed
Yeah, I would like to know also..
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
This thread is like a sasquatch...reported sightings, but no pics. I too am interested, but not willing to throw money at parts that wont work. I know someone out there has done this already.
Jarhead79
Mt Vernon il
Michael
Lol, same here, my only hold up is the rear brake lines and whether or not I can go without a proportioning valve. I checked at my part time job and all the prices are about right for the 99 to 2000 awd astro van setup. With my discount it's rreally worth it to upgrade vs drums, etc
Jarhead79
Mt Vernon il
Michael
I don't think he was saying he knows someone personally, but that he knows it's been done somewhere. Lol
74 Shortbed
Yeah, kinda thought that after I posted, tried to delete it but wouldn't let me. :confused:
kdo58
Puyallup wa.
k5
74 Shortbed
Thanks for the links.:cheers:
77c102door
Newark
Harjeet
i've been reading other forums and i think alot of people are using lt1 calipers with 94-96 impala rotors. Lt1 caliper have built in ebrake, so it should work with stock
Camar068
10 yrs Air Force
I might have missed it scrolling through, but I don't think anyone threw up a link for the 8 lug folks. Complete kits that won't break the bank.
https://lugnut4x4.com/
Harleyboy1
Santa Rosa Texas
Adan
Harleyboy1
You wouldn't happen to have the part number for the caliper brackets would be great
I haven't seen any write ups on this so I thought I would pass some info along to everyone. If you are wanting to put rear disc brakes on your truck this is the cheapest way I have found to do it while using new parts. From 1999-2001 chevy offered the astro in a awd. The front rotors on it just slide over the wheel studs. The bolt pattern on the van is the 5x5. If you go to oreily auto parts you can pick up a new set of these rotors for $35 a piece, the calipers for the van run you $11 a piece and you can pick up a set if caliper brackets off of speedway motors for $11 a piece. Which brings your total to a whopping $114. Which I thought was a hell of a deal when you compare it to a kit from other places that usually start out at around $500. Hope this will be help to some people.
thompson22
Greenville, South Carolina
ANTHONY
I am in the process of starting to do the rear disc brake conversion. I an using 94-96 Impala SS drilled and slotted rotors, calipers, and rear brake lines for the Impala as a direct fit without using any adapters. I am on another site where there's a guy that makes the caliper brackets to bolt right on to the rear. I also have 95 Impala SS slotted and drilled rotors on the front as well.
thompson22
ANTHONY
These are pics of the caliper mounting brackets and the Impala SS Front rotors I just installed on my truck with 3 inch drop spindles.
xXmutantXx
