fast 99
- Dec 31, 2021
- Spokane, Washington
- Brian
- K20
This should be relatively easy to diagnose. If the old drums were dragging that's a clue. Go back to basics. Make sure the shoes are retracted onto the anchor pins and emergency brake cable is free. Then if residual pressure is suspected open a bleeder. Like I said in the first post, incorrect shoe size will be obvious if they are placed in a drum. They should have a very similar [not exact] diameter.
Match up the remaining parts. Make sure it is assembled correctly, primary and secondary shoes are in the proper location.
I have seen shoes that had too much material for the application, may be a couple times in 30 years. Do the basics first, then the odd problems.
