Rear brake chatter during low speed braking
Grandads1980
Newton, KS 67114
Earl
Ok guys grandads 1980 k20 scottsdale sat for a couple years and now I'm getting out and stretching it's legs daily. I've noticed a, what I'd call, a chatter and/or rear brake lock up coming to a stop. I thought at first it was the clutch staying engaged slightly due to saggy cab mounts. But in gear or out, clutch pressed or not it's still happening. Cab mounts and clutch issue hopefully will be fixed this weekend. I put new tires on yesterday and neglected to pull the drums off and look at them. Front pads are ok for now but on the near future list. Could I have knocked something loose inside the drums hammering on the lug nuts with the impact or do you guys think something else could be happening? I will try and sneak a peek at the shoes through the inspection holes tommorrow. It's bugging the dickens out of me right now though.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Yeah, you’re gonna have to pull that and get a closer look. Maybe pits in the drums from sitting so long causing the chatter and/or your shoes are adjusted too tightly causing the grabbing?
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
The dickens right out of you huh? Might wanna see a doctor about losing your dickens.
Pull the drums though. Something's froze up or separated in there.
Grandads1980
Newton, KS 67114
Earl
Update--- blown drivers rear wheel cylinder. Any tricks for getting the drums off? Thanks in advance.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Depending on what rear you have they will either just pull off or you will need to pull the axles. Back off the adjusters as far as you can. It will help.
78C10BigTen
pennsylvannia
C10 BIG TEN
I was gunna suggest this!!!! My 78 c10 was doing the same thing. And it was the wheel cyl
78C10BigTen
pennsylvannia
C10 BIG TEN
I'd love to do that conversion. Lol its just not in the budget. Maybe a couple years farther into restoration.
Im in the same boat but there are ways around it... astro van rear disc setup
87ScottW
