Rattle in oil pan below 700rpms
usar17
PA
K20 Silverado
TBI350/700r4/NP208
It is not speed-dependent. I can drive the truck with overdrive off and I never have the shake
Sent from my SM-G950U using Tapatalk
Oldrider
NC
k2500
Glad you found it. Were you able to get new bolts tight?
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Yes. Just need to solve this shake
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Start with the easy. Get the tires balanced. The direct drive can make something like that more noticeable where some converter slip can mask a lot. Just read a thread elsewhere that mentioned a miss in the engine being accentuated by the lockup. Once an injector was replaced it went away.
Edit: another poster in the same thread fixed theirs with ujoints
kenny78
Oklahoma
Ken
1973,1980,1982,1985
Blazer(2) k30&k20
Do check simple rings first. I took my 4l80e in to be rebuilt-had a bad shake in 4th gear. On the phone with trans guy he warned of the very same thing as above posters. The lower rpms of high gear and lockout can unmask engine or drivetrain vibrations.
For me, it was the overrun clutch welding to whichever planetary blah blah. Transmission rebuild.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
My transmission was rebuilt 2,000 miles ago
usar17
PA
K20 Silverado
TBI350/700r4/NP208
I had no issues in lockup prior to dropping the transmission and swapping that flexplate
Oldrider
NC
k2500
I had an issue when stopping. I replaced the rotors and all is nice again.
kenny78
Oklahoma
Ken
1973,1980,1982,1985
Blazer(2) k30&k20
I didn't mean to imply that it was your trans. A down cylinder etc can become more apparent under these load conditions.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
So.... definitly my predominate shake from the driver side of the engine. I have it out idling trying to see where its more from. I swear its a LOT quieter running motor then normal.... dead cylinder? Both injectors are spraying.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Good vacuum test. Steady 18/19 in Hg.
crazy4offroad
Curt
K-10
350/SM465/NP205
Start it up cold and spray a squirt bottle of water on the header tubes/manifolds close to the heads. It will sizzle off quickly from the cylinders that are running and linger on dead cylinders.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Hot damn I got her fixed. Love working in the fire department, a lot of guys had past jobs. Talk to a buddy of mine that ran of shop for years he told me to check out the distributor cap. Well in the process of getting ready to switch that I noticed cylinder 3 wire was smashed between the engine and bellhousing. New cap and wires and she's running like a new truck
CSFJ
It's the simplest things that create the biggest headaches. Lol
Oldrider
NC
k2500
Hooray!!!
glad you found it
87R10_Cruising
