R4 to Sanden whith stock ac lines(for serpantine)
fortune46x
Iowa
Alex
5.3 LS
As far as wiring goes with the Sanden to the connector on the firewall , do you just plug the single wire into the light green wire on the fire wall ? or the dark green wire on the firewall ?
gmbellew
Kansas city
glen
suburban 1500
you want to tap into the single wire going from the low pressure cutoff switch on the accumulator to the original compressor. I forget if it is light or dark green....but don't bypass the low pressure cutoff switch
c5killer
Sean
V1500
Gen III 6.0L org. 5.7 TBI
This is the info I have been looking for.
@yevgenievich, all I can find are the 8 rib clutches for this model compressor. Did you have to special order a 6 rib?
yevgenievich
Viktor
sad
very sad
less sad
Used 8 rib and let it ride on 6. There is a special order 6 available, but a pain to get I believe
c5killer
Sean
V1500
Do I need to swap out my high/low switch on the accumulator to one for r134A or just keep the R12 one?
gmbellew
Kansas city
glen
suburban 1500
existing switch is fine, but you may need to adjust the pressure it cuts off to account for the temp/pressure differences to get better cooling.
yevgenievich
Viktor
sad
very sad
less sad
Either adjust or get one that is set for 134
Backfoot100
Florida
Eddie
C1500 Suburban
Carbed 350
Where exactly is that switch and how do you set it?
R Carnella
Long island
Rich
Suburban V2500
If yours is adjustable then there will be a small flathead screw between the two electrical contacts. It's on the receiver/dryer
Backfoot100
Florida
Eddie
C1500 Suburban
Carbed 350
Awesome.
My apologies beforehand for sounding like a rookie. I've been hearing about this switch ever since I did my Sanden conversion but I've always been confused about....
1) Where it is. Thanks for the info.
2) and this is the real question now, would you be increasing or decreasing the switch pressure????
The conversion process from R12 to 134 confuses me. Does higher pressure mean colder air or does lower pressure mean colder air?
Doppleganger
OH-MI: Just like it sounds
I've converted probably 25+ older cars from R12 to R134. The pressure switches were always different. ?! They were always mounted on the accumulator.
yevgenievich
Viktor
sad
very sad
less sad
Awesome.
Turn the adjustment about 1/8 to 1/4 counter clock wise if I recall correctly. R134 needs to lower pressure couple of psi. Adjustment is best done with gauges and a running system to observe cut off pressure
gmbellew
Kansas city
glen
suburban 1500
R Carnella
Long island
Rich
Suburban V2500
You'll need the ac system running, fully charged and a decently warm day. Connect your gauges and watch low side press. Raise engine rpm to 2500 or so and watch As the low side(really suction side)drop, if low pressure falls below the set cut off point, the switch will open the circuit and turn off the compressor around 35psi.
I turn that little flathead counter clockwise about quarter turn for a lower cut off around 25-28psi.
Keep in mind this is just fine tuning for your ac system, it's not absolutely necessary to mess with this,your ac will work regardless. Much more important to have the correct charge for your system overall. Adjusting this only helps to prevent the compressor cycling on/off to much on cooler days like if you're using defroster on a rainy day and to prevent freezing over in cold climate. On a hot day with system under load your low side pressure should stay around 40/45. Far above the cut off point anyway.
gmbellew
Kansas city
glen
suburban 1500
from the service manual on which way to turn the switch
krogers98gmc
