Q-jet rebuild
83K5guy
Corpus
Justin
K5 Blazer
Looking to rebuild the qjet on the k5 and was wondering of any tips or tricks on rebuilding em. I know I have read and seen people drill the base plate iirc and putting a bushings in to stop fuel leaking from the butterfly rod. Any other things to do and any advice.
MrMarty51
Eastern Montana
Martin
Some nice tips in this article http://www.carcraft.com/howto/57178/ most notably where to epoxy the leak-down prone areas.
When doing a rebuild on a Qjet and it comes time to disconnect the accelerator pump arm and linkage,I drive the roll pin that is through the body and accel. pump arm,drive it through far enough to release the arm but not so far that a screw driver can`t be placed between the pin and air horn to push it back through upon reassembly.thats all.well,take a few real cood pics. of the mass of linkage before disasembling.now,thats all.
woodsrider250
Fredneck, MD
350-Qjet
Good idea.....I did mine recently, and it had been a long time since I touched a qjet. I dicked around with the fast idle stuff for 30mins unnecessarily....LOL
MrMarty51
Eastern Montana
Martin
Years ago I was sent to a training school and the items on the agenda was the "NEW" Delco HEI ignition systems,the Delco internal alternators and the Q jet carbs,it has been a lot of years since that schooling but it seems that I did`nt forget that training,I do stumble on the linkeages and the adjustments but that is why they send them instruction sheets along,if followed in order then that takes out a lot of the pain.It seems that IF I take some time out and read that sheet from top to bottom before removing even one screw then it jars them dead brain cells back to life,well,some of them any how,and it makes the rebuild process much easier,adjustments too.
Them old "Motors" manuals are invaluable for setting up and adjustments.
On the choke pull off I use a drill bit to measure how far the choke will pull open with the vacuum pump hooked to the dashpot since I dont own an angle guage,I thinking it was a 5/8ths inch drill bit
504SquareBody
