PS turn signal intermittently works
Stroked
Beloit, Kansas
Jared
Ok, so I wired in a new front DS turn signal socket, replaced burned out bulbs, and replaced the blown turn signal fuse. Turn signals worked great until I drove around town.
Now the PS turn signal only works if I tilt wheel up or down and get it in just the right spot. DS turn signal still works perfectly. Thoughts? Time for a new turn signal switch? :hmm:
J Knight
Baytown TX
82 Chevy
350ci
Sounds like turn signal switch may be going bad.
Stroked
Beloit, Kansas
Jared
That's what I was guessing. Maybe a short in one of the wires going through the tilt pivot point.
Sent from my iPhone 4s using Tapatalk
J Knight
Baytown TX
82 Chevy
350ci
If so its part of the wire harness thats permanently attached to the switch.
Stroked
Beloit, Kansas
Jared
A new switch comes with a new harness then, correct?
J Knight
Baytown TX
82 Chevy
350ci
Yes, the wires from the switch are about 6in long or so and plug in about halfway down the side of the column to the truck harness.
Stroked
Beloit, Kansas
Jared
Awesome! Guess I'll see if the local parts store can get me a new one. Thanks!
chengny
Here are a bunch of pictures that I took a couple of years ago. They vary in quality from undiscernable to great. Don't expect too much - they are in no particular order and have no text but they might help you pull the column apart and (maybe successfully) reassemble it. I had to tilt my steering wheel so far forward (to keep the wipers from starting when not needed and not stopping) that I felt like I was driving a Peterbilt.
Download the zipped files from Deposit Files - no PW.
http://depositfiles.com/files/m8o6z2xvb
http://depositfiles.com/files/zr56zwzet
Some samples:
Stroked
Beloit, Kansas
Jared
Those will help a bunch, I'm sure. Thanks! :cheers:
CmuCmu
