preformed brake lines
wick
Grants Pass, Oregon
C-10 stepside
I am a newbie, have a 80 step side, power disk/drum. I have been attempting to replace all of the brake lines. I ordered a set from Classic industries that were "preformed" thinking it was an easy bolt on project. The steel lines weren't formed correctly and I had to hand bed them, not a good idea. I ordered another set and the lines coming from the master cylinder were off 180 degrees, talked to their tech and he is sending a different set for 81-87 to see if they fit better.
After all that, my question is... what is the difference between the 2 groups of years for brake lines and master cylinder? Thanks in advance.
In the 80's, the master cylinder was often an aluminum design with a plastic tank. But it also varies between 3/4 ton and 1/2 ton.
No matter the year, the lines are run roughly the same. If some bends were off 180 degrees, it was probably a manufacturing hiccup.
wick
Grants Pass, Oregon
C-10 stepside
Thanks bucket, Just out of curiosity I checked AutoZone and punched in 1980 then 1982 chevy c-10 for their master cylinder. there were cast MC for both years with different part #'s. I did see the plastic ones you talked about. just wondering why the 2 choices 73-80, then 81-87. and the 2 choices for the brake lines.
I just think their line kits are not exact fit, just "generally fits".
There are so many variations over the years, there's no way it can be covered with just a couple generalized year splits.
wick
Grants Pass, Oregon
C-10 stepside
I ordered a new front brake line kit from Classic industries for 81-87 trucks, got credit for returning my second order of 73-81. The tech took a picture of the line in question, and it looks more similar. Also ordered a 73-80 kit from inline tube. both will arrive next week, eager to see the difference.
Please let us know how it goes!
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
With booster or without booster is the difference. I have a 86 C10 stripper with disks on front but no booster.
wick
Grants Pass, Oregon
C-10 stepside
thanks, but why the change in brake lines and master cylinder starting in 81?
Shorty81
Baby Boomer
North West ohio
Darren
Some 1979 components carried over on 80's. Depends whether it is a early 80 or late 80. I ran into a mess with my last 80. GM was ramping up for the " all new 1981 truck" and they used up what they had to build out old stock.
wick
Grants Pass, Oregon
C-10 stepside
that makes sense. There are some parts catalogs that don't even state the year 1980, they will go 73-79 and 81-87
CiscoKid
California
Gary
Another option is to buy the nickel/copper tubing off Amazon or your favorite store and make your own. It bends easy and shouldn't rust. Cheaper and way easier to work with compared to stainless lines. I bought a flaring tool and it worked great. This was my first time doing this and would definitely go this route if I ever did it again.
wick
Grants Pass, Oregon
C-10 stepside
Good option.
Just received my replacement lines (81-87) from Classic Industries. Just eyeballing it for now, it looks a lot more like it should be. Still strange because my truck is a 1980. I am waiting for a delivery tomorrow from in-line tubing for 73-80 truck and will compare and give a posting on what I have found. thanks for the idea CiscoKid.
As Shorty81 pointed out, 80 might be a conglomeration of 'old"style and 'new' style parts
wick
Grants Pass, Oregon
C-10 stepside
Received the lines from in-line tubing today for 73-80 c-10. I laid them down next to the lines from Classic industries 81-87. They are very similar. The only real difference I could see was the larger (1/4 inch) line had a different bend after the loops coming out of the master cylinder. Either package looks like they will 'work'. Guess I'll find out when I go to install them. Sorry for the shadows. The lines with the red covers are from Classic (81-87).
wick
Grants Pass, Oregon
C-10 stepside
All done. when comparing the two brands, Classic Industries and Inline Tubing, They are close, but I would go with inline tubing, the bends are more like factory originals.
This is a side note.... I also replaced the proportional valve. I purchased a plastic "bleeding tool" to go in where the brake switch is located, Supposedly to keep the switch from activating while bleeding. I kept having a small leak but couldn't tell exactly where it was coming from, I assumed a bad valve. As it turns out, the brake switch has an o-ring, the plastic tool didn't. I put an o-ring on the tool and no leaks.
Snips71
