Power Steering pump differences?
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
I just finished up doing a serpentine conversion on my truck. I got everything off a 1990 C1500 2wd truck and transferred it to my 1986 K10 I'm using my existing high pressure and return hoses. Everything works extremely well except for the power steering, it is much tighter to turn the wheels than before. With the old pump it was extremely easy to turn from lock to lock and had more play. now it's much tighter and less play. It has power steering it just feels a lot different. My question is, is there a difference between the internals of a 2wd pump and the 4x4 pump? And if you pull the cap off the pump, while the engine is running, can you see movement of the fluid in there? I ask because mine has no fluid movement.
chengny
No - there are no internal differences between the two model years you are working with. From 1985 through 1990, whether the application is the C,K,R, or V series, all those trucks use the same power steering pump rebuild kit.
As I'm sure you suspect, any differences would only be found in the external details (the mounting configuration, pulley style/diameter, location of return/supply ports, etc.).
I never really looked or thought about it, but the pump's discharge port is hard piped all the way through and out of the casing - so you definitely wouldn't see that flow.
And as far as the return line; although it's last section (inside the reservoir) is open ended, it terminates below the design operating level. Also, to reduce the chance of aeration, the last section is fitted it is designed to act like a nozzle that directs the flow of incoming hydraulic fluid in the downward direction. So as long as the fluid in the reservoir is kept at the normal level, you shouldn't be able see any flow from the return line either.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
Thanks Chengny. I guess I bought a defective one from Autozone then. Gonna take it off and get another, and see how it turns out. Its been a week, and the steering is getting stiffer and stiffer, at times it gets caught now.
yevgenievich
Viktor
sad
very sad
less sad
My replacement pump from autozone was also less assist than original. Replaced only because their new steering box dumped all fluid out on a long drive.
Rusty Nail
Rusty
350sbc
Pulley diameter is the same?
A difference would modify fluid flow...
Perhaps the pump no longer spins at an equivalent speed.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
The pulleys seem to be the same diameter in size, just now I'm using a serpentine pulley instead of the v-belts.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
Correction, the serpentine pulley is bigger than the v-belt pulley. I took in the pump, and got a new one, put it on and I'm glad to say its working as it should. Steering feels like butter again. We'll see how long this half ass autozone pump will last this time. If it goes out again, I'm gonna bite the bullet and order a quality pump online.
joseph916
