Power steering pump bracket
jaygdub
Prescott Az
Jay
K5 Blazer
Does anyone know where I can buy a power steering pump bracket (no ac) for a 1985 chevy 350? The engine is out of a K5 Blazer. Thanks
chengny
Front bracket - I'm guessing - is P/N 14081277:
You could try either one of the vendors below. But I'll bet the first one is full of *hit - about having it in stock. And as far as CI, when exactly, is soon?
This is almost surely going to be a junkyard purchase or some kind of aftermarket modification. Or, if you can wait - and get lucky - one might pop up on ebay.
https://www.concord-parts.com/goods/14081277/GM
GM 14081277
BRACKET
$12.42 stock check 09/15/2017
https://www.classicindustries.com/product/g11672.html
Product #: G11672
Arriving Soon!
MSRP: $20.99 ea
Classic: $18.99 ea
There's tons of engines that used these brackets. Just find one, release the 4 bolts from the front housing assembly - and the two adjustment locking bolts (3 & 4). Pull the bracket off the pump. DON'T forget to grab that spacer (item 7) - that's another obsolete part. And if you don't have one to copy, your belt alignment could end up being off.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Just stock stuff? I got stuff from my 87 and an 89......
chengny
That would work - if you also give him item 21 in the dwg. From 87 up (86 for CK3 series), the front bracket became...like a full face design, which utilized three mounting points. That is probably what came with your 87/89 350 M's.
Previously, just two bolts were used to secure the pump/bracket - the pivot bolt and one (upper) adjusting bolt. The full face bracket had another hole for a lower adjusting bolt - and that "S" shaped brace (21) was required if that lower bolt was going to be used:
Thing is, if the P/S pump mounted fine using just two bolts up till that point, it may well be that the lower one isn't really critical.
michaelmarine53
