Please help ID my axles!!
throttle out
Michigan
Sam
5.3 LS
I'm pretty certain my rear is a 12 bolt. But the front has me questioning my judgment a bit. When I first started trying to identify my axles, I was guessing it was a 10 bolt. But the more searching I do the more I think its a Dana 44.
Truck is a bit of a Frankenstein.
Its got an 87 R10 cab with tbi 5.7 & 700r4. I was, up in till this point calling it a 87 V10 pickup, but my understanding is that an 87 would have had a 10 bolt up front from the factory. of course there is always the chance someone swapped it out.
Thanks for your help!!
Lugnut
Northwest Georgia
Jason
'79) 350/ granny 4-speed, '86) 350/A833 3-speed with overdrive
Look for the number 44 cast next to the drivers axle tube.
Here is a pic of mine.
throttle out
Michigan
Sam
5.3 LS
Nice!
Thanks bud, will do!
It's a 44, which wouldn't be original to the truck.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
44 front, 12 bolt rear. You can tell it's a 44 because it has 2 spring u-bolts on passenger side. D60 would have 1 u-bolt and then 2 bolts on the other side that run right into the carrier. Otherwise their covers look the same at a glance.
throttle out
Michigan
Sam
5.3 LS
Thanks fells.
aaron06
